Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: New IAT VE Multiplier Table
    Default New IAT VE Multiplier Table
    Hello all,
    Been a bit of discussion about AFR's changing with hot Intake Temps.
    It has been confirmed enough times to make us do something about it.
    I recently added in a new 2D table to some of the custom O.S V3's to compensate for this condition.
    I plan to have all V3 O.S's patched by the time I leave for SEMA (next week on the 25th).
    You will just need to full flash the new O.S in, then your existing cals from the V3 tune you are already running then change the new table.
    Here's how it works.
    In a nutshell it just multiplies the VE table number based on the Intake temp, it would be the same as recalibrating the VE table at 90deg or 160deg, except you just calibrate the VE within a certain window of intake temps then apply the error factor once the intake temps get up.
    See the graphs below referring to the table values (bench PCM log).
    NEW TABLE:
    With IAT at 115 the VE table value is 4.000
    With IAT at 172 the VE table value is 4.099
    With IAT at 219 the VE table value is 4.200
    With IAT at 266 the VE table value is 4.400
    foff667
    Guest
    very cool new feature 8)
    Lifetime Member mistermike's Avatar
    Dec 2003
    good deal!!
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Oct 2003
    Quote Originally Posted by foff667
    I agree. Thanks......pursuit of perfection (you guys..not me).
    Oct 2004
    Ross,
    I hate to ask, but is this going to be put into the V2 Custom OS's also, for those of us not running boost? :( Or should we just upgrade to the V3's anyway? :wink:
    Andrew
    EFILive Crew
    Thanks guys,
    This table will not go into V2 O.S's, sorry, it's a fair amount of work altering the VE routines, not as much as you having some fun upgrading to a V3 O.S (which you can run without boost, I am).
    Oct 2004
    Ross,
    :oops: I am probably guilty of being the person that as changed OS's on my car the most times. I have run V1, 2 & 3 OS's, and gone back from 3 to 2 etc. :oops: Just ask black02ss, he'll tell you, we laugh about it
    Andrew
    EFILive Crew
    Jul 2005
    Is this info going into the OS Tutuorial or the AutoVE Tutorial?
    Lonnie
    2002 EB Coupe, MN6
    Xtreme TTi Twins @8psi, Dual A-pilar gauges - fuel&boost, x-pipe, Borla Straight Twin Oval from Cats on back, Hurst Short Throw, CCW 3 piece rims - 18x9.5/275-35 and 18x11.5/335-30 Pilot Sports
    Drive it like you stole it!!!!!
    Jan 2004
    Quote Originally Posted by Tordne
    Ross,
    Oh don't get me started. This dude puts a new OS on his car like every hour. :lol:
    Oct 2004
    Quote Originally Posted by black02ss
    It's not that bad :oops:
    Ross: any chance that you have done 01290003?
    Andrew
    EFILive Crew
  1. COS 5 Fuel VE multiplier
    By Highlander in forum Custom Operating Systems
    Last Post: October 25th, 2022, 06:56 PM
  2. Table[B5108} RPM Spark Multiplier ???'s
    By GAMEOVER in forum E37, E38 & E67 PFI ECM's
    Last Post: September 19th, 2011, 08:18 PM
  3. IAT VE multiplier table A0014 Q's.....
    Last Post: April 7th, 2008, 01:56 AM
  4. Math for the VE multiplier
    By Beer99C5 in forum Custom Operating Systems
    Last Post: September 8th, 2007, 01:56 AM
  5. VE Multiplier vs. TPS vs. RPM table, with non-linear TPS...
    By SSbaby in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 11:46 AM
