Results 1 to 10 of 11
Thread: Vortec 7.4, 0411 PCM, Standalone Harness...got a ?
    Sep 2009
    Default Vortec 7.4, 0411 PCM, Standalone Harness...got a ?
    I just completed the 0411 PCM swap on my 97 model Vortec 7.4. This engine is in an 89 suburban using a standalone wiring harness, from Painless. I have loaded the calibrations for the 2001 Express Van. The OS running is 12212156. I do not have a VSS hooked up since the 89 suburban didn't have one. I am using a 4spd (SM465) transmission.
    Here's the issue: cranks and idles fine, but if I try to rev it up when it gets to a little under 2000 RPM it tries to die. I am wondering if the abuse management parameters are making it do this? If I ground pins 32&34 on the blue connector as if I were going to do a crank relearn, then it doesn't do this at all. Maybe the abuse management is kicking in because I don't have VSS hooked up, manual trans, and no park neutral or clutch signals?
    Jul 2005
    You are correct. You need to raise your Abuse Mode Enable rpms, or give the PCM a VSS input, or ZERO out your Abuse Mode Disable Speed.
    peace
    Hog
    1997 rcsb stock L31 longblock, Marine Intake with 28# EV6 injectors, L35 2700 stall TC,Hooker LT's 2.007 60ft
    Aug 2007
    also raise your p/n rev limiter otherwise it won't rev passed that because the pcm thinks in it in park. I have attached a stock camaro tune with no autotrans, try doing a transmission segment swap to eliminate any autotrans related issues.
    Sep 2009
    Thank you both. I modified the abuse mode parameters and that did the trick. Now I am wondering if I have a sluggish O2 sensor making the LTFT on one bank lean out more than the other by about 6-7%, or is that OK? The reason I suspect the sensor is because I have one old one and one relatively new one. The engine seems to idle pretty good, but throttle response seems poor until it gets up to operating temp. I am VERY new to EFI tuning
    Would someone like to take a look at the tune I am using and see if anything stands out with the engine parameters? I received the file from another helpful user to have a starting point. The tune was originally for a 5.7 Express Van and I don't know how much it has been changed to account for the 7.4. I modified the injector flow rate since I also installed a set of LS6 injectors, rated to flow around 32lbs at 4 bar, but I set it to 31lbs due to some figures I found online where someone had a set flow tested.
    Aug 2007
    Do you have access to a wide band o2 sensor, I am thinking that some ve tuning may be in order since the 7.4 is going to have different fuel requirements than the 5.7. I also compared a vortec box cal for the 7.4l, to the tune your running the maf sensor calibrations are a little different, are all the sensors orginal to this engine? Shoot over to holdencrazy.com efilive tune library, compare the 7.4l tune to yours to see the differences. The ve tables are in different values tho, may want to try a 8.1l ve table and see how it runs.
    good luck
    Sep 2009
    I don't have access to a wide band o2 at the moment, but maybe I can find someone to loan me one temporarily. All sensors on the engine are stock. Thanks I will look at the 7.4 tune on that website and see what I come up with.
    Jan 2007
    The MAF numbers will be different.
    You'll need to do an AutoVE and then do the MAF.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Sep 2009
    Quote Originally Posted by hquick View Post
    Thanks! I was comparing some different tuning files and noticed that was the big difference. It looks like my next tuning investment will be a wide band O2 sensor.
    Sep 2007
    Default 0411 7.4L tune but with the 4l80e/diff cam
    Here is one tune in the works that was already done with a wideband with stock injectors but a slightly larger cam than stock... but not much bigger
    its currently in a 97 k1500 truck and it's a 2000 454 in it with custom wiring harness.
    Sep 2009
    Thanks I will take a look at the file. The issues I am having now are: engine tries to stall sometimes when I am cruising along and push in the clutch to stop, and I keep getting a DTC from the IAC system saying the RPM is too high. I need to do more driving to confirm, but the DTC seems to trigger when I am braking while leaving it in gear and not pushing the gas pedal. I am thinking the IAC system is trying to lower the RPM but it can't since it is still in gear? Also I think the stalling issue will be fixed once I get a VSS hooked up, but that may be a little while.
  1. 0411 swap on 99 Vortec 454
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 22nd, 2013, 12:49 PM
  2. E38 Standalone harness ?'s
    By GAMEOVER in forum E37, E38 & E67 PFI ECM's
    Last Post: October 16th, 2009, 09:29 AM
  3. 0411 computer in 2000 S-10 w/5.7 Vortec
    By lowriders10 in forum Vortec V6/V8 Specific
    Last Post: June 19th, 2009, 01:03 PM
  4. Wiring for 97 vortec to 02 0411
    By redhotrod in forum Vortec V6/V8 Specific
    Last Post: November 19th, 2008, 03:57 PM
  5. Custom OS on 0411 PCM for L31 Vortec?
    By N0DIH in forum Custom Operating Systems
    Last Post: October 24th, 2007, 04:24 PM
