Results 1 to 6 of 6
Thread: Need Stock Tune
    Dec 2007
    Default Need Stock Tune
    Does anyone have the stock tune eng/tran for the new 2010 Camaro SS with auto? The Camaro was tuned using HP Tuners and I wanted to use EFI Live to read the tune and compare it to the stock programing to see what was changed. Unfortunately, it was tuned(w/45 kilometers on the clock) before I could read the stock file.
    here you go
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Dec 2007
    Thanks for the help.
    I tried comparing it to the custom tune in the Camaro but I couldn't because the operating system was different.
    Then you have to either copy all the tables in the tune to another copy of this OS and then compare them or fire up both tunes side by side and compare. When V8 is released it will allow you to compare different OSs.
    Dec 2007
    Is there an easy way to copy the stock tables to my OS? Or do I have to go table by table to do it?
    Quote Originally Posted by SRT10KLLR View Post
    If you want to take the time to create a script then you can try that, but otherwise its table by table.
  1. i need a stock tune
    By saltflat in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 1st, 2009, 07:34 AM
  2. LQ9 stock tune?
    By ALLslowNOshow in forum Gen III V8 Specific
    Last Post: September 21st, 2008, 08:32 AM
  3. Tune VE and MAF tables or leave VE stock and tune MAF only
    By BlackGMC in forum Gen III V8 Specific
    Last Post: August 4th, 2008, 08:05 PM
  4. Stock 04 Z06 tune
    By badsi in forum Gen III V8 Specific
    Last Post: May 12th, 2008, 10:47 AM
  5. Stock 07.5 Lmm Tow Tune
    By newguy2diesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 29th, 2007, 11:26 AM
