Results 1 to 7 of 7
Thread: Code P062F and Code P0633 Help
    Mar 2008
    Default Code P062F and Code P0633 Help
    Cannot start my truck and getting two codes P062F and Code P0633
    What should I do?
    I tried to upload and new tune with no luck. It shows the tune took but still will not turn over and still shows codes.
    Help
    Mar 2008
    Maybe I should order a back up ECM? What is a good place to buy one?
    Is this a 2001 model by chance?
    Has been a problem on 2001's from the day they came out.
    If you want to try another ECM see this thread:
    http://forum.efilive.com/showthread.php?t=11325
    Also see if you can get an updated OS put in it (I'm still assuming this is a 2001 truck).
    Mar 2008
    Its a 2008 GMC LMM.
    Oh, that changes things. You need to get the ECM updated by the dealer, it's a known fault with the LMM. If your ECM OS is not 12628594 then that is the problem.
    Since he has already locked his V2 to his ECM, any way he can just flash it with someone elses 8594 OS and bypass the dealer? But then you get into the whole CVN dealeo.
    Not quite, there is slight variances with each model truck, if he knows someone with the same model and options that has the updated OS, then no problem.
    It should still be a warranty issue though.
    http://duramaxdiesels.com/forum/showthread.php?t=5079
  1. Wtf authentication code????
    By LMMpioneer932 in forum FlashScan V2
    Last Post: April 13th, 2010, 11:16 AM
  2. egr code?
    By hutch in forum Duramax LLY
    Last Post: October 3rd, 2009, 04:55 AM
  3. code question
    By justin123 in forum Gen III V8 Specific
    Last Post: April 29th, 2009, 10:12 AM
  4. key code
    By beaukz28 in forum Purchase and Shipping
    Last Post: October 14th, 2008, 04:35 PM
  5. Code P0480
    By Chalky in forum Gen III V8 Specific
    Last Post: August 19th, 2007, 03:29 PM
