Thread: Engine braking in DFCO
    Sep 2009
    Default Engine braking in DFCO
    Hey All, (1st post)
    Is there any way to control the throttle opening while in DFCO?
    I want less engine braking in DFCO. Throttle follower only seems to have an effect until DFCO cuts in.
    This is a great forum BTW, absolutely everything I needed was here to get me up and running with my LC-1 , Thanks so much,
    Wayne
    Wayne,
    DFCO kills the fuel to the engine.
    No matter what throttle opening, timing is used NO fuel means NO fuel, and henceforce engine friction is what determines how much braking effect your combination will make.
    You can alter how quick DFCO comes in and make it feel seemless when coming in by the use of the injector cut sequence.
    John
    Dec 2006
    Can you please tell me what DFCO stands for?
    8.7 @ 84 (1/8 mile) bolt-ons
    Deceleration Fuel Cut Off.
    Dec 2006
    I knew it was fuel cut something lol. I actually looked in a tune before asking but could not find a description. Thanks a lot again!
    No worries...
  1. Brake Tap Grade Braking
    By killerbee in forum Duramax LLY
    Last Post: October 7th, 2009, 03:51 PM
  2. Engine braking
    By Rich in forum Gen III V8 Specific
    Last Post: December 26th, 2008, 08:48 PM
  3. A4 Engine Braking
    By neil in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2006, 03:42 PM
