This doesn't seem right. Table B5108 the IAT says(link.SAE.RPM) and RPM(link.SAE.IAT)
In my data log it reads 82 degrees F and 4600 RPM but in the table it's highlighted at 248 degrees F and 0 RPM
I'm logging both SAE.IAT & SAE.RPM PIDS.....
FLASHSCAN V2 & AUTOCAL
lol.....
I get 0 RPM and 120'C IAT......
I normally sanity check the highlighted cells though, as I've seen them off a few times. Normally it's when I have more than one copy of Tune Tool open to compare different settings from different tunes. In this case though, it doesn;t seem to work with only one copy of Tune tool open.
Simon
Yeah, I was trying to figure out why in the my Tune I'm commanding 23-25 degrees of timing but in the Scan tool it always shows 5-12 degrees more...
There are a few tables that can alter timing. You could always post the tune and a log and I'll have a look.
Simon
Ill post the tune and a log later today...
Maybe i'm not logging the right Pids for Cam Phaser timing or Minimum final timing...IDK
I've run into the same issue tonight looking over some logs from the track. In B5108 the axis are backwards in the cal_link.txt file. Not to mention all of the spark tables for E67s (I'm using OS 12618164 in particular) still refrence E38.APCYL_DMA which is a bit frustrating since I can only log E67.APCYL_DMA with black box logging. I also noticed that intake valve temp tables are linked to E38.INVLVTMP_DMA in an E67 OS, I'm not sure how critical that is? I've manually changed my cal_link.txt file to get it all to work but was hoping this could be addressed in a near future update?
Simon,
I finally figured out were the extra timing was coming from "cam phasing" at certain points it would add up to 15 degrees but I had to add the cam phasing table/file into my cal_link.txt file, it wasn't there!... I also changed the cal_link.txt for IAT vs RPM Spark Multiplier and the tune tool & scan tool finally link right! The ROW & COL in the cal_link.txt file was backwards...
As handy as the cal_link.txt file is, it tends to be like a high maintenance girlfriend, really cool to show off to your mates, but always causes problems so one day it will have to be replaced with something better
Version 8 software will have a better implementation of this file that will get around the sort of problems you see (like the PID names E38_DMA v's E67_DMA). Manual of editing of the cal_link.txt is the solution at the moment.
2014 VF SV LS3 Maloo.
