Results 1 to 3 of 3
Thread: TH400 upgrade now speedo is way off!!!
    Jul 2007
    Default TH400 upgrade now speedo is way off!!!
    We have a 2005 GTO in the shop and have converted it to a TH400
    It had a T-56 in it from the factory
    We install the correct reluctor wheel and speedo sensor in the car but it still is waaaaaaaaaaaaaay off...Its over 10 MPH off and we have no idea what to do to correct it
    This car didnt have a TCM as its an 6sp car...We are thinking in might need a Auto engine tune and a auto dash to correct this issue but again we are not sure...
    Any help would be great
    Lifetime Member johnv's Avatar
    Jan 2005
    go into speedo calibrations table H0101 and either add or subtract a % untill it reads correctly. Read the table discription to determin which way to go.
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    Feb 2006
    did you change H0102 from 17 to 40?
    this would definetly cause your speedo to be out.
    Just use the calculator but make sure you put 40teeth for the pickup
  1. Speedo calibration VSS in Scan not same as speedo
    By maudyZ28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 23rd, 2010, 01:47 PM
  2. speedo help
    By justin123 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2009, 12:15 PM
  3. 07 C6 A6 Speedo Cal
    By Mike@Vengeance in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 18th, 2008, 03:26 PM
  4. 4l60e to TH400 car wont go above 2000rpm
    Last Post: October 10th, 2007, 10:00 PM
  5. 4l60e > Th400
    By Macon@MMP in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 10th, 2007, 01:07 AM
