Results 1 to 3 of 3
Thread: ecm locked bootloader rejected
    Jul 2009
    Default ecm locked bootloader rejected
    this is on a 06 LLY.
    efi has detected that this ecm may not have a valid calibration
    ecm does not contain a valid calibration
    bootloader rejected
    reason: efilive could not unlock the ecm
    using alt keys i get bootloader rejected response code $11
    Jason, is this from the blx files you sent me today?
    If so, it looks like you are trying to use the V1 hardware on that truck, if so it's not possible as the V1 has no CAN bus support (which the 06 LLY is).
    Jul 2009
    ross, ya i brain farted this was my first 2006. thank you for your time.
    jason
  1. bootloader rejected
    By relentless addiction in forum Duramax LLY
    Last Post: May 25th, 2010, 07:26 PM
  2. Bootloader rejected
    By lilly in forum Duramax LLY
    Last Post: June 28th, 2009, 02:48 AM
  3. bootloader rejected
    By dmax687 in forum Duramax LLY
    Last Post: November 8th, 2008, 12:43 AM
  4. bootloader rejected PCM locked
    By rubbersidedown in forum Gen III V8 Specific
    Last Post: July 30th, 2008, 10:16 AM
  5. Bootloader Rejected
    By KWSUNDELL in forum Duramax LLY
    Last Post: October 21st, 2007, 08:32 PM
