Hi everyone, I am planning to purchase FlashScan soon to use on a project I am undertaking. I'm installing a 2002 LQ9 (6.0L 10.1:1 compression genIII truck engine, used in escalade and SS) along with a 4L80e transmission (used in 3/4 ton and heavier pickups) using a 2002 PCM and wiring harness from a 3/4 ton truck into my 95 chevy pickup. I need to come up with a PCM image that will support the 4L80e and have calibration that will run the higher compression LQ9. Would I be able to take the calibration on my PCM now, for a low compression 6L motor and 4L80e, and copy the engine tables from another vehicle equipped with an LQ9 motor easily with EFILive's offerings? If not, what is the best way to go about doing this?
My next question regards electric fan control. I'd like to use the PCM to control my electric cooling fans. I see the camaro LS1 computers have a provision for two speed fan control. Is there a way to make this feature work with my 2002 truck PCM? Of course I would have to add pins to the PCM connector and what not. Thanks in advance.
Patrick
