I have all my air flow settings to kpa with most every thing else set to imperial, as it is easier for me to convert in both the scanner and the tuner. but when I log MAP kPa and then try to review it in and see where I'm at in the 0101 table, the gray box acts like it is getting data from in inHg form and never leaves the first 3-4 boxes. When I change the units to inHq if follows like it should in the table. Is this a bug, or do I have something not set correctly.
