Results 1 to 4 of 4
Thread: pcm noy detected on scan only wtf?
    Dec 2009
    Default pcm noy detected on scan only wtf?
    ok i just go my roadrunner pcm from another member. i put the license info in the license part. i can communicate with the rr but when i try to connect with the scan only via the obd2 port it says pcm not detected but at the bottom of the scanner it says connected. where it says pcm not connected is int he black screen part in the console section. i put connect and on that part while trying to connect it says pcm not detefted, ecm not detected. wtf lol any help thanks
    using windows 7.
    Nov 2006
    Do you mean TCM?
    LC1 vehicles do not have a TCM.
    As long as the status bar shows connected and
    the OBDII options are active you are connected to the PCM.
    LC-1 WBO2
    Dec 2009
    Do you mean TCM?
    on there it says it but it says
    pcm not detected
    ecm not detected
    tcm not detected
    could it be related to vats?
    cause when i do a full reflash with my bin on the rr pcm it works initially. i can connect on the scanner and when i turn the ignition only the fuel gauge and my fuel pump are working(98to 02os). the fuel pump primes for 2 to 3 secs and the fuel gauge works. but then i go and close the file after a reflash. and i turn the ignition off and retry to connect and it wont let me, the above pcm ecm and tcm say not detected. also the fuel pump only primes for half the time then what it should and my fuel gauge jumps to full, but it was working before i turned the igntion off wtf
    Nov 2006
    Try performing a VATS re-link.
    In the Tune.exe there is a key icon at the top tool bar. (Ctrl+Home)
    Then try setting {G1201} Anti Theft Configuration to None.
    This maybe necessary because of the 98 PCM conversion.
    I think it is also necessary to consolidate the 3 connectors from
    the PCM to the IPC into 2.
    http://www.lt1swap.com/98-02_ls1.htm
    Did you do a segment swap for the fuel system?
    I don't know which vehicle it needs to come from but
    I do know it must be from the same OS.
    LC-1 WBO2
  1. Interface not detected problem
    By icetraxx in forum General
    Last Post: January 12th, 2010, 08:56 AM
  2. error interface not detected
    By drdarthinvader in forum FlashScan V2
    Last Post: December 7th, 2008, 06:11 PM
  3. What could cause timing to be pulled with no KR detected?
    By ArKay99 in forum Gen III V8 Specific
    Last Post: September 15th, 2008, 10:09 AM
  4. Problems with upgrading V2 from scan only to scan and tune...
    By DngrZne in forum General (Petrol, Gas, Ethanol)
    Last Post: November 26th, 2006, 03:41 AM
