Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Error BBR 98 PCM
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    Default Error BBR 98 PCM
    I read two 98 PCM's successfully (?) (after reformatting the SD Card). One works with the Tune tool okay the other one gives me an error message when I load it into the Tune tool, but it does allow me to look at it. I've attached the error information and the tune (.ctd) files zipped. The LS1_0005 file is the one that gives me the error. The LS1_0006 seems to be okay. I used the verification step on both files.
Name:	EFILive Error.jpg
ID:	6382   Click image for larger version.
Name:	EFILive Error 2.jpg
    Sep 2003
    If I read the bad (?) PCM with the PC everything looks good. I just noticed two recent Bug reports, so I've included them also.
    Sep 2003
    Dec 2005
    Try and read it to the internal memory and see if you have the same problem?
    2011 LML 3500HD CC D/A 4x4
    2006 LBZ 3500 CC D/A 4x4 Sold
    2001 LB7 2500HD D/A 4x4 Sold
    I have your files but have not analyzed them yet. I'll be getting to the 98's by the end of the week.
    It may be a faulty file system on your SD card or internal memory. Try reformatting whichever memory you are saving the files to before reading the file from the vehicle.
    Sep 2003
    I formatted another SD card and had the same problem. I emailed the files to you on 10/08.
    Any progress on this ?
    Sep 2003
    Default Error Code $0502
    I updated to the latest builds (100 & 80) and upgraded my firmware to 2.06.19 and when I tried to read my two spare 98 PCMs I got an error $0502 'script file not found'. When I looked at the 'Options.txt' file I found this:
    *TUNE_SELECTIONS
    ;Caption Active Module
    F/Y Body|97/98, Y, LS1A_A
    LS1 99+|, Y, LS1B
    E40|, Y, E40
    I removed th "_A" from 'LS1A_A' and now I can read the PCMs, however one still reads good and the other does not. The good read is the LS1_0004.zip file and the LS1_0005.zip is the bad read.
    Thanks.
    Sep 2003
    I got an error code $051A length of file incorrect or something like that after the LS1_0005 read and I saved a trace file (USR_0007.zip)
    Can you switch on BBXStats in the FlashScan Setup screen.
    The retry reading the failed PCM. See if the Stats show any retries which indicates comms issues.
    I'll fix the Options.txt file - thanks for finding that.
    Nov 2006
    About the options.txt
    I could not drag and drop PIDs to it.
    I ended up using the last one I had after the new formatting update.
    Is this OK?
    LC-1 WBO2
  1. Error BBR 98 PCM ... again
    By Ninety8C5 in forum FlashScan V2 BB Logging
    Last Post: March 5th, 2010, 10:24 AM
  2. ERROR. Please help
    By ntrimm in forum FlashScan V2
    Last Post: March 29th, 2009, 03:22 PM
  3. RAM Error
    By bobo in forum FlashScan V2 BB Logging
    Last Post: February 26th, 2008, 11:59 AM
