So, I've been fighting knock issues forever. I put a whole new intake on, and today just replaced the knock sensors and wires (old ones were corroded). Engine is a 10.6:1 LQ9 with stock cam. I am 99% sure this is false knock but I have no clue why its doing it. At WOT it went to 7+ degrees of timing and there was no change in noise or anything from the engine. I never hear any knock. I also noticed that if you have my tune and log open at the same time with the high octane table open the values don't correspond. For example it does 23.5 degrees of timing whereas I have 20 listed in the table. I'd appreciate any input. Thanks.
