Results 1 to 7 of 7
Thread: running rich between shifts??
    Lifetime Member smslyguy's Avatar
    Oct 2008
    Default running rich between shifts??
    I am running between 9.5 a.f.r. to 10.5 a.f.r. between shifts. is it b3645 supposed to be adjust for this? or b3643? and what should be entered in to slow this process down?
    2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
    Now own a 2015 1LE camaro
    Nov 2006
    A4 or M6?
    Sounds similar to what asked. Stomp or Impact
    I have been taking sections out of a chart in order to examine how much
    AFR decreases with TP% when coming out of PE and between shifts,
    then using that average to decrease B3428.
    Results have been mixed and I have not been able to check my latest changes.
    LC-1 WBO2
    Oct 2008
    Quote Originally Posted by mr.prick View Post
    A4 or M6?
    it's a m-6
    Oct 2008
    A4 or M6?
    so what did you find out? I take it this is a common problem?
    Nov 2006
    Neither of these worked for me.
    I would be inclined to think it was VE related but it can happen at low RPM
    as well as high RPM and I know the low RPM areas are right.
    LC-1 WBO2
    Jul 2007
    Do you have a log? Is it the the same as issue as mr.prick is getting or something different?
    Oct 2008
    Quote Originally Posted by swingtan View Post
    it sounds like it is, mine just hits like 9.5 afr to 10.5 afr between shifts or on let off as well.
  1. Car is running VERY rich all of a sudden
    By alwaysinboost in forum Custom Operating Systems
    Last Post: June 8th, 2009, 11:01 AM
  2. Car is running VERY rich all of a sudden!
    By alwaysinboost in forum Gen III V8 Specific
    Last Post: May 19th, 2009, 03:03 AM
  3. 5.7 running rich.
    By DmaxHawk in forum Vortec V6/V8 Specific
    Last Post: January 21st, 2009, 06:40 AM
  4. Why is it running rich?
    By Garry in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 05:05 AM
  5. It's running a little rich
    Last Post: January 23rd, 2007, 02:30 PM
