Results 1 to 3 of 3
Thread: clarification on semi closed loop SD
    Mar 2007
    Default clarification on semi closed loop SD
    I have COS5...everything runs pretty good in OLSD. I daily drove it this way and have run at the track this way for a few years. Today, I put my o2s in and set every cell from 0-75kpa and 0-2800 rpms to 14.63 commanded afr (commanded afr vs rpm table) . I noticed the STFT adjusting (LTFT at zero and disabled) and wideband is pretty stable around 14.7. I figure this will give me good/stable fueling at idle and cruising. What I do NOT want is the o2s to affect my WOT in ANY way. Do I have this setup properly?
    My scans today always report Open Loop and LTFT at zero since they are disabled but I do get STFT corrections now. It SEEMS the STFT hit zero when i go 100% tps while idling but since its raining I didnt get to try it on the street. I want ZERO o2 influence on my WOT.
    It seems you are setup correctly...
    the B3647 WOT cells (>80kPa, >5000rpm) would be richer than stoichiometric (14.63), so semi-open loop will not affect WOT...
    semi-open loop only enables for those cells set to stoich afr (0-75kPa, 0-2800rpm in your case);
    semi-open loop uses STFT's to trim.
    Mar 2007
    thanks thats what I thought. I want to see if the O2s can get my mileage better with the weather swings here in Ga
  1. cos3 semi closed loop
    By kostelacd69 in forum Custom Operating Systems
    Last Post: September 11th, 2009, 08:49 AM
  2. How to REALLY shut of closed loop/ force open loop
    By Tomato in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 03:37 AM
  3. semi closed loop
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: August 12th, 2007, 01:58 AM
  4. closed loop and open loop switching
    Last Post: July 10th, 2006, 08:56 PM
  5. Open Loop SD VS Closed Loop SD Advantages???
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2005, 12:25 PM
