Results 1 to 4 of 4
Thread: Need definition for 16197427
    Oct 2009
    Default Need definition for 16197427
    I need a def file for my truck, it is a 95 S10 with a 16197427, it is $0D. I found a link to a definition download page but it doesnt work. Hopefully one exists. I'm trying out this software because I cant get TunerPro or TTS to successfully connect, it use to but then I did a MPFI swap on my truck and ever since I have not been able to connect. It says it is successful but it is only at about 5Hz and will only receive on good packet followed by 10 or so errors then another good one, it makes the data very jumpy and unusable.
    It'd be really nice to also find a def for $31, its the same PCM but the different code is used in the HD trucks with 4L80E's, its a lot less popular so I dont expect to find that one, I had to make one for tunerpro, TTS did have it though.
    One other thing, maybe not the place to request this but I have my wideband on the Linear ERG input, if the $OD def had that I couldn't ask for more.
    Dan - ASE certified-A1, A4, A5, A8
    95 S10 ecsb-350ci, Ported 906 vortec's, L31 intake, 9.5:1, Crane(.484/.512 216/228 112LSA), Hooker Super comps, 2.5" ORY, cutout, 40 series flow, 4L60E, 8.8 f*rd posi w/ 3.73's, 7427 PCM in MPFI mode, $OD, WB02.
    95 K2500 rclb-350ci, 4L80E, exhaust, 7427, $31.
    Have you looked through the ALDL file from here:
    ftp://ftp.diy-efi.org/pub/gmecm/
    Oct 2009
    Yeah I found the one I need in there last night but I dont know what to do with it. The one I need is A179.dl but how do I convert that DL file into a useable xld file?
    The EFILive V4 documentation explains how to create/edit the vehicle definitions. Look in the section(s):
    • Reference->Vehicle Definitions
    • Reference->Modules
    • Reference->Requests
    • Reference->Requests->Attributes
    Warning, don't add any comments to the comments section when creating the definition. There is a bug in the underlying xml system (that we can't fix) that can cause your "work in progress" to be lost.
    I recommend saving the vehicle definition after adding each attribute and copy the file to a different name. The bug actually wipes the file on disk - so just saving regularly will not prevent data loss.
  1. MEFI 4 ECM definition file
    By blazerdude in forum EFILive V4
    Last Post: May 10th, 2016, 01:33 AM
  2. DSP Output definition
    By killerbee in forum General (Diesel)
    Last Post: July 5th, 2009, 03:12 PM
  3. Additional PID definition ?
    By gmh308 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 24th, 2009, 12:05 PM
  4. Custom/DIY calibration definition file?
    By jimter in forum General (Diesel)
    Last Post: October 10th, 2007, 09:25 AM
