I updated everything for BBR except now I cant BBR. I also still get contact dealer when I plug the V2 in with the car running. Where is the options text that Im missing or what did I do wrong? When I select to read I get a message no options text?
Did you copy all of config files over to FlashScan or AutoCal?
FLASHSCAN V2 & AUTOCAL
You can use Scan&Tune->BBL to create a new Options.txt.
I didint copy them over, where are they?
Joecar how do you that?
Open up EFILive_Explorer(make sure AutoCal or FlashScan are connected) under config. files click on the "HOME" button, and all you do is copy/drag those files over to bottom screen...
Sorry about weird screen shot...
Did you follow the V7.5.6 upgrade .pdf? You need to format your V2 completely then use S&T to copy everything over, the options.txt file has changed. Solved my problems in the early beta stages.
