Results 1 to 5 of 5
Thread: Bootloader error when getting stock tune
    Oct 2009
    Default Bootloader error when getting stock tune
    I just got EFILive yesterday and when trying to read the stock tune I keep getting th ebootloader error. Also my vin and bcc are messed up on the Calibration Info screen. I have read the forums and am assuming that my ECM is corrupt. I read the TCM fine but get the errors when doing the ECM. If it helps out I have tried a Bullydog Power Pup and ATS E Power and neither would work on my truck. I emailed support with the .blx and a sdreen cap of the Cal Info screen and hope that someone there or on here can help me out with this. Thanks.
Name:	vin & bcc info.jpg
    03 Dmax LB7 auto
    Trevor, unfortunately it looks like your ECM has been corrupted at some point (hence, no VIN, ECM Serial etc). You might have to consider another ECM at this point, check this link here to see what he has:
    http://forum.efilive.com/showthread.php?t=11325
    Oct 2009
    Thanks for the reply, thats what I was figuring. I guess I'll have to get a ECM sometime now.
    03 Dmax LB7 auto
    Oct 2004
    Thanks Ross. I got your email Trevor and looking at the debug it definitely looks like the PCM is not right.
    Andrew
    EFILive Crew
    Oct 2009
    Well I bought an ECM fro killerbee, now I just gotta wait until it gets here. Is it very hard to swap out the ECM?
    03 Dmax LB7 auto
  1. Bootloader Error
    By Hawk355 in forum Duramax LB7
    Last Post: April 29th, 2012, 01:35 PM
  2. bootloader error will not reflash
    By toolie in forum Duramax LB7
    Last Post: June 20th, 2010, 10:10 AM
  3. Bootloader error and no calibration!
    By horsehaulin in forum Duramax LLY
    Last Post: August 16th, 2009, 04:25 PM
  4. Bootloader Rejected error during reading calibration data
    By Godwin1245 in forum Gen III V8 Specific
    Last Post: January 26th, 2009, 01:25 PM
  5. Tune VE and MAF tables or leave VE stock and tune MAF only
    By BlackGMC in forum Gen III V8 Specific
    Last Post: August 4th, 2008, 08:05 PM
