Results 1 to 10 of 13
Thread: V1 and licenses on 98 ECU?
    Oct 2009
    Default V1 and licenses on 98 ECU?
    I saw this for V2 cables, but I have a V1 will it still give me unlimited licenses for 97/98 ecus?
    Unlimited tuning licenses for the LS1A 97-98 GEN III PCM is free with any FlashScan V2 purchase.
    If your FlashScan V2 does not have the LS1A stream activated, please "purchase" this product to receive your free LS1A activation code.
    Thanks,
    All 97-98 LS1 controllers should be free to tune with either EFILive cable IIRC, let me pull my V1 out and see what it says.
    That is true. You can tune unlimited 97/98 LS1 PCMs with V1 and V2 cable. The part about "purchasing" just means to go here and "purchase" the LS1A stream. The cost is $0.
    http://www.efilive.com/index.php?pag...mart&Itemid=56
    Quote Originally Posted by LibertySyclone View Post
    The V1 cables have the unlimited LS1A stream (i.e. 97/98 LS1) built in when they are manufactured.
    Thats what I thought, thanks for refreshing my memory Paul.
    Dec 2012
    Wish I had read this earlier.
    Quote Originally Posted by kainedogg View Post
    How come, did you accidentally purchase a VIN license for a 97/98 LS1?
    Mar 2007
    I'm sure it is just bad timing, but I also fell into the LS1A license issue about 3 weeks ago. I had heard that they were "free" but wasn't sure how it all worked. Luckily for the guy whose car I was doing, I had a couple extra licenses on my V2. That way I could still do his car. I figured at the time, that the V2 would just see it was an LS1A, and not use a license. Unfortunately, it appears that I didn't need to use any licenses, just upgrade my V2 with the LS1A stream. Lesson learned, but it would be nice to get that extra license back ...
    Quote Originally Posted by turbo_bu View Post
    If you send me the tune (*.tun) file from that LS1A vehicle and the license backup file (*.lbu) file from your V2, then I can get the VIN license refunded or replaced whichever you prefer. Plus send you the activation code for the LS1A if you don't have that already.
    Send the files to paul@efilive.com
    Lifetime Member tokymon's Avatar
    Apr 2008
    is this the black box ( pick-up )files you're talking ? being free
    0r the lt-1
    97 2500 ecsb 5.7l/4l80e/4x4 411 pcm /thorley tri-y's/dual super 40's with x (catless)/aem cai/msd 6a and coil/zz4 cam/beehive spring/lm-1
    stock sucks
  1. Missing licenses!
    By Burnt_Bizcut00 in forum FlashScan V2
    Last Post: November 12th, 2009, 08:00 AM
  2. Transferring Licenses
    By 06Dmaxpwr in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 3rd, 2008, 09:37 AM
  3. v2 licenses question
    By 88s10 in forum FlashScan V2
    Last Post: April 12th, 2008, 04:57 PM
  4. VIN Licenses
    By schuter in forum Purchase and Shipping
    Last Post: March 18th, 2008, 09:59 AM
