Results 1 to 5 of 5
Thread: PCM locked, had HP flash... can't access?
    Sep 2007
    Default PCM locked, had HP flash... can't access?
    any thoughts- i am sure i've been through this before, won't let me access tune on read (bolt-ons) changed to cam/ heads and brought to me for tune. I have unchecked high speed & check try alt keys. I "believe" the tune was not locked, but it was an HP cal. Do I flash in stock tune and start over (with tech II) or can I read it somehow???
    thanks
    Does it actually read the PCM then fail, or fail right at the start?
    Nov 2006
    If it's a pptuner COS then you won't be able to read it.
    I think it will be locked automatically if it is a pptuner COS as well.
    LC-1 WBO2
    Sep 2007
    does not read it.. kicks me out immediately.
    Hp locks their tunes if you load one of their Custom OS's into your ECM. It can be unlocked. I have unlocked a few of these...
    2002 Chevy Truck
    K&N Air Intake
    Dynatech Headers
    Noisy Lifters
  1. How do I get access to Bidi menu
    Last Post: January 12th, 2007, 01:03 PM
  2. Replies: 10
    Last Post: February 4th, 2006, 12:07 PM
