Results 1 to 9 of 9
Thread: dpf delete help
    Oct 2009
    Default dpf delete help
    i tried the dpf delete write up but im still having some problems,
    Did this- Change B2501 to No
    Did this- Change B2502 to 0
    I dont know about this can some one help me with this part- Set the regen min engine temp to the max value (ie: higher than opperating temps)
    Read this thread for more info on DPF: Ultimate DPF thread
    Junior Member Spuco's Avatar
    Dec 2009
    Quote Originally Posted by escalante127 View Post
    Where do i find these paramiters?
    2500 HD 09 Silverado LMM/CC/LB/Z71/LT1
    EFILive w/ DSP5 (Duramaxtuner.com)
    Spuco, welcome to the forum...
    Escalante127, welcome to the forum...
    Dec 2009
    Thank You, happy to be hear
    HAPPY NEW YEAR
    Nov 2006
    Quote Originally Posted by Spuco View Post
    Use the search box in the navigator window to find them without
    having to go thru every folder.
    LC-1 WBO2
    Dec 2009
    Quote Originally Posted by mr.prick View Post
    This is going to be a stupid question, so bare with me. The truck would need to be hooked up and running?
    Not required...
    In the tunetool you can search, view, edit tables without requiring to be connected to vehicle or to FlashScan...
    (there may be 1 or 2 "exception" tables that only show up when PC is connected to FlashScan).
    Apr 2007
    Seems that thread is missing some info.
    This is what I've came up with so far.
    {B2501} set to "NO"
    DTC Enablers to set to X: Not Reported, No MIL
    P2033-2032
    P0420
    P2455-2454
    P0546-545
    P2002
    P244D
    P244B
    P20E2
    P2453
    P2463
    P1448
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
  1. DPF and EGR Delete
    By pONSi in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 13th, 2010, 10:48 AM
  2. 5.3 o2 and maf delete????
    By kyl3 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 21st, 2009, 10:00 AM
  3. Dpf delete
    By LIL DAVE in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 9th, 2009, 07:24 AM
  4. 7.5 LMM DPF delete and EFI V2
    By clickjocky in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 5th, 2008, 03:36 PM
  5. Cat delete
    By Automotive Innovations in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 27th, 2007, 11:52 PM
