Results 1 to 10 of 17
Thread: Efi live and factory fast idle
    Feb 2009
    Default Efi live and factory fast idle
    Whos got it? What OS is it ???
    Since GM got rid of the elevated idle in cold climates
    i need a way to keep the truck closer to operating temp that wont affect drivability
    Stock 2006 LBZ
    Feb 2008
    I was running the 083 OS and I had it. Ill check today and see if its in my current OS that I switched to (the 94 os). I had start issues with the 083 os is why I had to switch to the current one.
    12 Second LMM
    Feb 2009
    8594 is what im on and it doesnt have it that i know of unless there is a way to activate it. Im talking the one thats more like a PTO control ebrake on and you can bump it up with the set and resume buttons.Not the elevated idle.
    Stock 2006 LBZ
    Oct 2007
    Quote Originally Posted by maxxflip View Post
    You need to have the high idle option for that
    Feb 2009
    Quote Originally Posted by LBZRCKS View Post
    So ive found out just though maybe since a guy on the same OS 8594 as me
    has both options on his so i though it might be in the OS and be able to be activated Guess not
    Stock 2006 LBZ
    Apr 2008
    I say it is a BCM related item. Seems like I seen a post over at Diesel Forums. Found the post i was thinking of. http://www.duramaxdiesels.com/forum/...ead.php?t=8875
    May give some light to you. so if you do the PTO deal it looks like a BCM programming will be needed. I have to say the cruise control idle deal as far as I can say is nothing but programming and why GM charges $200 for it I don't know. I guess they think they can but if enough figure it is a few simply on off statements then it be a bigger rip off than Windows OS.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
    Feb 2009
    Quote Originally Posted by Brian1 View Post
    Brian
    Im talking to the dealer about it tomorrow
    Stock 2006 LBZ
    Jan 2008
    The PTO stuff for the LMM is extremely complicated as compared to the LBZ and LLY/LB7. If i remember correctly the control for the PTO is in the BCM AND you need the steering wheel controls for it as well, because i think it uses CANBUS to operate it... And i don't think it was ever and option for the 2500/3500 trucks. Just the 3600 (cab and chassis) and the 4500/5500 series trucks.
    Another solution to your problem, though, is DSP2 or 5 just make a tune with elevated idle for one of the switch positions. LMM DSP is in beta right now and is probably going to be out for all OS's 2-3 weeks...
    Feb 2009
    It is in the BCM, havent had a chance to talk to the dealer yet about it
    it is an opton on the 25/3500 There is an aftermarket controller out there
    and im sure its not hard to build
    Stock 2006 LBZ
    Jan 2008
    Oh cool. I had just been doing a lot of reading and goin through wiring schematics and it looks really haggard to try to make something. I wouldn't doubt there is an aftermarket control for it that makes perfect sense but you still need the dealer flash to enable it.
  1. d2903 factory set at 10?
    By Ritch in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 20th, 2010, 01:21 AM
  2. Link to GM T43 factory calibrations?
    By C6Guy in forum Gen IV V8 Specific
    Last Post: May 14th, 2010, 07:37 AM
  3. what table controls how fast it drops to idle when slowing down?
    Last Post: September 8th, 2009, 08:18 PM
  4. PLEASE...Need '08 Z06 factory cal
    By KAZ MotorSports in forum E37, E38 & E67 PFI ECM's
    Last Post: March 30th, 2008, 11:58 AM
  5. Is The Factory Computer Ever Too Small?????
    By rustynuts in forum Gen III V8 Specific
    Last Post: January 18th, 2008, 06:35 PM
