Results 1 to 10 of 14
Thread: Custom operating system
    Mar 2007
    Default Custom operating system
    I have used a tune from Holden Crazy to tune a motor with Cable throttle using 1mb PCM. The operating system is 12606807. Is there a COS for this?
    Mike
    Oct 2004
    That is a late model (2006) OS for the LS1 controller. So, there is no COS for this I'm afraid. Do you need to be using the late model OS, or could you go back to say OS # 12587603 and therefore COS # 040730xx?
    Andrew
    EFILive Crew
    Mar 2007
    I was just using the latter one as it works with cable throttle, Will the earlier one work as well?
    Oct 2004
    I actually don't know 100% the answer to that. Did the 2005 Commodore use cable throttle still? If so you could use OS # 12592433 and COS # 041400xx. 2005 was the first year Holden used the 1MB PCM.
    Andrew
    EFILive Crew
    2005 commodore use's fly by wire
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Mar 2007
    OS 12587604 seems to work with cable throttle
    We did add the options matrix in the calibrations a while back, with that you can just tell the PCM, ETC or Non ETC.
    See G1206, G1207.
    Mar 2007
    Thanks guys thats all good, The motor starts/runs etc with close air/fuel, (loaded my own maps) Idles nice But misfires at revs and P0315 comes up. In order to do a relearn is it necessary to have foot on the brake......its a bit hard in a boat with no brakes
    Jan 2007
    Yes....foot on brake is necessary.
    I guess you can just ground that pin in the PCM....if you know which it is.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  1. Why run a Custom Operating System???
    By RacerChris in forum Custom Operating Systems
    Last Post: November 11th, 2008, 11:45 AM
  2. custom operating system nos
    Last Post: June 4th, 2007, 01:33 PM
  3. 98 Custom operating system...
    By 98SS2836 in forum Custom Operating Systems
    Last Post: March 19th, 2007, 11:44 AM
  4. 2 Bar Custom Operating System
    By Whippled2dr in forum Vortec V6/V8 Specific
    Last Post: January 21st, 2007, 09:17 PM
