We have a stock pcm from an 03 vette and are trying to buzz the motor past 8000rpm.
The car is tuned alpha-n (TPS vs. RPM) and this table ends at 8000rpm.
Initially we were getting a fuel cutoff right at 8000rpm so we decided to populate the main VE table with the thought that the PCM would default back to the main VE after the TPS vs. RPM table ended.
It seemed to work somewhat as we were able to now buzz the car to 8235rpm, 8350rpm, and 8475rpm on consecutive pulls BUT the car still experienced an abrupt fuel cutoff.
It seems that we are making progress but are not sure why the fuel is being cut and why at different rpms. The only thing we changed was a slight adjustment in AFR during the above pulls on the dyno.
The fuel pressure is rock solid up to the point where it cuts out and it acts like it's hitting a rev limiter. My tuner has mentioned that he has raised all 3 rev limiter options above this point(9000+).
-Could the injectors be maxing out? But why the abrupt fuel cutoff?
-Any suggestions on how to get around this?
-Do you think we have to manipulate the PCM or the software?
We want to buzz the motor to aproximately 9000 rpms.
Thanks.
Rob
