Results 1 to 9 of 9
Thread: idle tuning & airflow
    Lifetime Member ZL1Killa's Avatar
    May 2005
    Default idle tuning & airflow
    I have a 2001 trans am. I installed a cam and I was trying to tweak my base airflow (when cold) and then adjust my other airflow tables as necessary to get my idle better. It is not a big cam, I just haven't tweaked my airflow tables enough.
    where/what table is the base airflow.
    Right now I see Desired Airflow, Airflow Parked, Startup Airflow Correction, Startup friction airflow correction.
    What all tables/parameters are involved in Startup airflow & cold start airflow?
    -Stevo
    01 T/A WS6 #4984 STOCK 342HP and 352TQ [/b]MODS:Too many to list, PM...funny rear mount.. father/son build.
    [Quote :ur car is sneezing!!!!]
    I KNOW KUNG FU.
    My STS build: http://www.ls1tech.com/forums/showthread.php?t=631954
    453HP 475TQ @6psi
    .....CAM'd, IC'd, and 7psi'd #'s coming.....
    May 2005
    anyone know about idle tuning & base airflow?
    I KNOW KUNG FU.
    453HP 475TQ @6psi
    Hi Stevo,
    Idle isn't my forte [yet]...
    See if this helps:showthread.php?t=4661
    May 2005
    woops... should have looked for that.
    Thank you!
    I KNOW KUNG FU.
    453HP 475TQ @6psi
    Lifetime Member mvvette97's Avatar
    Jul 2007
    Are you just having cold start problems or what?
    Jun 2005
    Careful what you read in there. I hear that guy's an ass.
    Jan 2007
    Quote Originally Posted by SSpdDmon View Post
    Yeah.....I've heard that.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    lol...
    Jun 2008
    Thanks for the heads up....
    2003 Silverado 1500HD LT 4WD 6.0V CCSB,
    '05 LQ4, Cam 208/208 .554/.554-114, MP T76, STS Boost Cntrl, AlkyControl, TiAL BOV, LC-1, EFILive, 60# Bosch EV14, DynoTune Boost,FP & AFR, Walbro 255LPH,Transgo HD2, McGaughy's 3/5 Drop, Air Ride AOL, Flo-Pro, G-Tech Pro Times 0-60 4.395 Sec; 60' 1.823 Sec; 1/4 12.776 Sec.
  1. E38 idle airflow
    By KenB in forum E37, E38 & E67 PFI ECM's
    Last Post: May 29th, 2012, 12:20 AM
  2. Minimum Idle Airflow Tables
    By fperra in forum Gen IV V8 Specific
    Last Post: August 28th, 2009, 02:50 AM
  3. idle adjustments and airflow
    By heavyfoot in forum General (Petrol, Gas, Ethanol)
    Last Post: June 23rd, 2006, 12:35 PM
  4. Desired Idle Speed and Idle Airflow
    By Bowtieman in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2006, 11:07 AM
  5. Is there a way to make the pcm use the p/n idle airflow tables?
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: December 26th, 2005, 03:11 PM
