Results 1 to 10 of 18
Thread: Having some issues with BBR. $0101:No Data Recieved
    Jan 2007
    Default Having some issues with BBR. $0101:No Data Recieved
    well i installed the latest pre release, updated the firm ware to the newest as described in the instructions. I was able to connect to my truck, (BTW it is an 04 GMC Sierra w/4.8, running COS3 04073003), it downloads just fine no errors. Then when i go to pull the tune off the V2, i get
    $0101: No Data Recieved...
    I have tried formating and reloading all the config files, creating new option.txt file,.... I choose the LS1B module...
    Also the file itself shows to be 499k, instead of 726k like my regular files....
    You mean the file only partially uploads to your PC... (only 499K out of 726K)...?
    Jan 2007
    Nope, i mean when i look at the EFI Explorer under the tune part it only show 499k. Then when i drag that file off the exploer is when i get the error
    Before trying to drag the file from EFILive_Explorer to Windows Explorer, open the Trace window. To do that, click on the "drop down button" in the lower right corner of EFILive_Explorer and select "Hide/Display Trace Window". Then if the transfer fails, copy the data from that window to an email and paste it in this thread.
    Jan 2007
    thanks Paul, i will do that in a little while or tomorrow morning. I am on my work laptop.
    This is the same as what I see on my MacBook running WinXP...
    See attached files.
Name:	Error $0101 - No Data Received.png
    Jan 2007
    Here is my trace file and screen shot, notice the size of the tune, 499k, when my 04 truck tune is 726k
    from trace:
    AddSourceFile \EFILive\Tune\LS1_0004.ctd Size=510473
    onGetStream: \EFILive\Tune\LS1_0004.ctd
    Apr 2008
    You might get a new 2gig or smaller sd card and try again. Some sd cards just die.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
    Jan 2007
    it works fine for my logs
    Quote Originally Posted by BlackGMC View Post
    from trace:
    With EFILive_Explorer running, before attempting to drag the file from EFILive to Windows, can you do this:
    1. Open EFILive_Hapi (double click on the FlashScan icon in the system tray at the end of the Windows Task bar).
    2. Select the F8: Trace option.
    3. Click [Clear].
    4. Drag the file from Explorer to Windows.
    5. Click [Refresh] in the EFILive_Hapi Trace window.
    6. Save the trace file (*.rtf) and attach it to this thread.
  1. Data log issues
    By Jakes4321 in forum Gen IV V8 Specific
    Last Post: April 13th, 2010, 05:58 PM
  2. I can no longer log data
    By Jasondt2001 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 12th, 2009, 12:09 PM
  3. Corrupt BB data
    By RevGTO in forum Gen III V8 Specific
    Last Post: June 15th, 2008, 06:48 AM
  4. L92 Data log
    By etmotorsports in forum Gen IV V8 Specific
    Last Post: January 26th, 2008, 05:04 PM
