Results 1 to 10 of 18
Thread: Help with software going corrupt
    Apr 2009
    Default Help with software going corrupt
    Blacky,
    Once again I cannot get the software to read my PID's from my log file on my notebook. I've been running great for a couple months since reinstalling Vista fresh. But Now the PID's are not showing up in F9. I know they are there. I can load the same log on another machine and they show. I need some way to identify what is clobbering your software. I recently added a lot of cam and movie editing stuff for my incar videos and since then, things went bad. I have removed and reinstalled your latest 7.5.6 version and that didn't work. Currently uninstalling and reinstalling to a different directory, but I doubt that will work for long.
    Please come up with something to debug what is going on. I need the notebook to do the flashes and really should not have to have ONLY EFILive running on it so that it behaves.
    Ken . . .
    Do you have any screenshots...
    Apr 2009
    Sure Joe, see attachments. Again, the software is not recoginizing the logged PID's on my notebook. I can open the same exact Log file on two other desktops just fine. I could even send it to you and you would open it just fine. I can't keep reinstalling Vista on my notebook everytime this happens. It takes many many hours to re-install all my stuff.
    You will see one screenshot showing only one data item logged, the other shows a ton. Two different computers opening the same file. The problem installation has been uninstalled and freshly installed with the latest version today!
ID:	6471   Click image for larger version.
    Nov 2006
    The A/D PIDs are the only ones missing data.
    Did you configure the A/D PIDs in the V2 before BBL?
    F4>F1>F1
    A/D PIDs: YES
    LC-1 WBO2
    Apr 2009
    F4>F1>F1
    A/D PIDs: YES
    I think you missed VSS, TP, MAP, IAT,KR etc.
    Unless you are saying you opened it and saw them all. If that is the case, you have seen my problem. The file is good, but on my notebook it will not see the PID's. I don't care about the A/D ones.
    2001 Corvette Z06
    Nov 2006
    I see them.
    The only PIDs not showing data are the A/Ds.
    I am using XP.
    LC-1 WBO2
    Apr 2009
    I see them.
    I am using XP.
    Now if you can help me to see them, my problem will be fixed
    My software on my notebook does not see the logged PID's, see the first screenshot above.
    2001 Corvette Z06
    Nov 2006
    Did you replot the log? Shft+Ctrl+R
    If the the Disable confirmation dialogs box in the scan tool properties is checked
    then you will not see anything until you replot the log.
    If it is unchecked the dialog box will appear when opening the log.
    LC-1 WBO2
    Oct 2004
    I can also see all the data in the log running latest pre-release build on Windows 7.
    Andrew
    EFILive Crew
    After loading a log file, sometimes the list of PIDs shown in the [Data F9] tab page will not refresh correctly. To force them to refresh, click on one of the gray column headings to re-sort the data by that column. That will force a display refresh and possibly restore the PIDs that you cannot see.
  1. Old Software...
    By MMLMM in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 19th, 2010, 07:05 PM
  2. Pass through logs corrupt..?
    By samh_08 in forum FlashScan V2
    Last Post: April 19th, 2009, 03:13 PM
  3. Corrupt BB data
    By RevGTO in forum Gen III V8 Specific
    Last Post: June 15th, 2008, 06:48 AM
  4. New LBZ Software
    By GMPX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 4th, 2007, 08:34 PM
