That sounds very familiar. Concussions have handicapped me. Plus a little aged.
Let's start with this then,
({GM.MAIN1T_DMA}+{GM.PILOT1T_DMA})*sqrt({SAE.FRP_C })/({CALC.CYLAIR}*16115)
determine what this yields in a zero boost log, then solve for the variable to make the logged EQ good to 0.6.
Does that sound like a plan?
Custom Tuning Services
I think that is correct.
So if you are running down the hiway (zero boost) and eq is logging, on avg, 124 (hypothetical), then the new PID constant becomes, (124/0.6) * 16115=3330400
I backed the PID into old logs, it looks to be not too far off as written. .3-2.1 range on the (hypertech) log.
That 2.1 is on the wot section, exactly as predicted, during spoolup. NOW, what can I do about it?
side note: this log is the just the worst performance imagineable, some of these cookie cutter companies should just committ suicide.
edit: something was wrong with that truck, idle MAF was logging 2 lb/min
Hmmm. Ok, well i'll have to play with it some and see what i can find out.
I agree! I had a BullyDog before EFI and owned the two at the same time so i pulled the BullyDog tunes with EFI and was shocked at the lack of "skill/craftmanship" (for the lack of a better term) in their tunes. I felt utterly sick knowing those tunes were being run in my truck...
