Results 1 to 8 of 8
Thread: anyone have a pid file for aem ugeo wb with the v1?
    Apr 2008
    Default anyone have a pid file for aem ugeo wb with the v1?
    im trying to get my aem ugeo to work with my v1 but im not having much luck. anyone have any ideas? i just downloaded the 7.5 build 88 version. thanks.
    Nov 2006
    Which AEM?
    There are a few with different outputs, one is non linear.
    This calc.pids.txt for dual sensors and the non linear dual sensor (30-2300 & 30-23001)
    calc_pids(AEM).txt
    Disclaimer: the non linear PID has not been tested.
    LC-1 WBO2
    Apr 2008
    im not sure if its linear or not im borrowing it from a friend. this isn the one i have though http://forum.aempower.com/forum/inde...c,21559.0.html last link at the bottom model 30-4100
    Apr 2008
    ok i tried using the calc that you posted but it was way off what the gauge was showing. i then went to aems site and copied all the lookup voltages compared to the afr it seems closer but not quite there...
    Nov 2006
    It fixed it.
    Analog Output Voltage Mode: P0
    LC-1 WBO2
    Jun 2007
    I read in another thread that you could get away with using the PLX PID's for the AEM 6 in 1 part number 30-4100 wideband as they use a similar linear formula. For simplicity I used the plx pid's for my aem and it appears to be working well. Is this an exact match or is there anything wrong with me using the plx pid's for the long term?
    Nov 2006
    The PLX and the linear AEM are the same.
    LC-1 WBO2
    Jun 2007
    much thanks prick
  1. 98 s-10 os file
    By haulinit in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: May 20th, 2010, 11:10 AM
  2. P12 PCM file
    By Chevy366 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: June 29th, 2009, 09:28 AM
  3. Would someone be willing to look at a log file?
    By stigmundfreud in forum Gen III V8 Specific
    Last Post: May 6th, 2007, 09:47 AM
