Results 11 to 20 of 27
Thread: LMM Pulse table
  1. #11
    Jan 2006
    That makes sense. Makes for another excel project.
    Custom Tuning Services
  2. #12
    Feb 2008
    Wow, I thought I was loosing my mind and a recent tune I did was acting wierd. So I loaded it into my truck and loged it and was not seeing the vales in the cells. I had to adjust for it;. I finally got it to work correct, and I should have said something, but I forgot about it lol. Thanks for bringing this up Mike.
    when will those cal files come out again
    12 Second LMM
  3. #13
    Feb 2008
    Here is a visual
    12 Second LMM
  4. #14
    Jan 2006
    Are you sure it doesn't read:
    1
    10
    30 (skip 20)
    40
    etc
  5. #15
    Jan 2008
    Quote Originally Posted by killerbee View Post
    1
    10
    30 (skip 20)
    40
    etc
    Why do you suspect that? LBZ's have the 20 row...
  6. #16
    Jan 2006
    Look at the scaling of the idle area. A smooth idle usually uses about 20-25 us per mm3. This keeps pulse from going ballistic (lope) in the idle speed control function.
    546 to 997 represents a doubling of pulse from the previous interpolative values of 304 to 546. 45us per mm3 (or 22us per mm3 if my hunch pans out)
  7. #17
    Jan 2008
    hmm... interesting theory.
  8. #18
    Jan 2006
    strangely though, I have a feeling it is as originally stated. the mid pressure values suggest this.
  9. #19
    Jan 2008
    Ah, how annoying, I 'thought' I fixed that. Yes the axis labels are not right.
    It should be:
    1.0
    10
    20
    30
    40
    45
    50
    55
    60
    65
    70
    75
    80
    85
    90
    95
    105
    120
    Will be fixed in the next .calz file release.
    Uh, Add LBZ to that list Ross. I was using the not-so-resent version of the calz. and since then have updated them, and now the LBZs look like the LMMs???
  10. #20
    Jan 2006
    I will be releasing new calz files in a couple of days.
    are these posted somewhere?
  1. throttle pulse
    By lb7blksmk in forum Duramax LB7
    Last Post: November 15th, 2009, 09:49 AM
  2. B4005 Small Pulse Adjust How does GM create this table?
    By onfire in forum Custom Operating Systems
    Last Post: December 2nd, 2008, 01:39 PM
  3. injector pulse width max?
    By pero648 in forum Gen III V8 Specific
    Last Post: April 5th, 2008, 12:47 PM
  4. Speedo pulse limits
    By VHR in forum Gen III V8 Specific
    Last Post: September 19th, 2007, 05:41 PM
  5. Small Pulse Adjust/Low Pulse Width Injector Offset
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: September 4th, 2007, 09:05 AM
