Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: P12 no read
    Oct 2006
    Default P12 no read
    I started this as a separate thread of it's own .
    Tried reading a P12 3 times with "fast" read , no luck , sent 3 .blx files to support , then did a "snail mode" read (fast read , unchecked) , stopped reading data as well (184k of 1mb , 11:08 timer) , sent 2 .blx files to support .
    Using latest firmware and software for V2 .
    2006 Trailblazer
    I have your files, I can see the fault occurring in the trace files. It is still under investigation. i.e. I'm still trying to reproduce the same fault here so that we can figure out what is causing it.
    Meanwhile check out my post here: http://forum.efilive.com/showthread....888#post106888 (Post #16)
    It is also relevant to your situation.
    Oct 2006
    If you need something more let me know .
    Response to Above link :
    Hmmm , I have only had 2 Notebooks with EFILive on them , well 2 portables that are used for tuning , and the current one has been used to read the same PCM with the same cable and the same USB port .
    I will try the tweak and see but I kind of doubt the USB stuff is it seeing I can read the LS1B PCM fine with either Notebook or V2 BBR .
    I was going to sign up for the Beta testing of the BBR but was going to be out of pocket for a couple of months and felt it would not have been very helpful in the testing stages .
    Again Notebook reading failure , not V2 BBR . Have no problem with .ctd files .
    2006 Trailblazer
    Oct 2006
    Got around to finally doing the USB setting , will try on TB when it comes in for a landing today .
    Is there a reason why it is set to the lower setting ?
    2006 Trailblazer
    No reason, that's just the default. Increasing the buffer will not "solve" the problem, however it may allow the underlying drivers to cope better with whatever is causing the problem by giving the drivers more room to store incoming data and therefor more time to deal with the actual problem.
    I have heard from others that read/flash P12s that you may need to pull the fuse on the BCM (Body Control Module) to prevent it from interfering.
    Oct 2006
    Okay , will try the BCM trick and see .
    2006 Trailblazer
    Oct 2006
    Okay , tried with BCM fuse out , no such luck , still the same thing , no 'fast read' or 'snail mode' either .
    Any other ideas ?
    Just to make sure which of the 5 BCM fuses did the person pull , outside , inside ?
    2006 Trailblazer
    Is this on the 2006 TB you have in your sig?
    Oct 2006
    Yes , so I have access , well limited access to it .
    2006 Trailblazer
    Senior Member JustinD's Avatar
    Jul 2009
    I tried again tonight, I checked to see if it was locked and it says it is. I dont think it has ever been flashed with EFI Live before. What should i do now?
    2001 Chevrolet K2500HD Duramax
    Suncoast SCIV 1056
    Kennedy twin lift pumps
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    A few more go fast/truck pulling goodies!
    Tuned with EFI
    12.65 @ 107 1.71 60'
  1. read pcm
    By Grey Silver in forum Gen III V8 Specific
    Last Post: January 1st, 2008, 12:32 PM
  2. Can't Read TCM
    By ARK 99coupe in forum E37, E38 & E67 PFI ECM's
    Last Post: June 15th, 2007, 02:32 PM
  3. Read posts in search...read tut..LM1 help.
    Last Post: March 15th, 2006, 02:00 PM
