I had an issue reading an 07 P12 around New Years, only had 1 shot at it so I forwarded the .blx and appropriate files to support. Seems I needed to pull the BCM fuse, Ill try it next time I see the truck.
Ok, thanks, I'll try my buddies truck again too.
2001 Chevrolet K2500HD Duramax
Suncoast SCIV 1056
Kennedy twin lift pumps
Billet pick up
MBRP 4" exhaust
Air intake horn mod
ARP head studs
A few more go fast/truck pulling goodies!
Tuned with EFI
12.65 @ 107 1.71 60'
I'm going to try today, I was having the same issues with my buddies 03 Dmax, EFI support helped me update yesterday.
Suncoast SCIV 1056
Billet pick up
MBRP 4" exhaust
Air intake horn mod
ARP head studs
Tuned with EFI
Thought I recognized the handle from the other forum . Do let us know if updating all software and firmware does resolve the issue.
Andrew
EFILive Crew
I haven't tried the LB7 Duramax yet, but the Trailblazer (P12) seemed like it read it, then when it was finished it said bad bin file? It said it saved it to my computer to send it to EFI support, how do I do that?
I will try the Duramax and see how that goes.
Thanks for all your help.
Suncoast SCIV 1056
Billet pick up
MBRP 4" exhaust
Air intake horn mod
ARP head studs
Tuned with EFI
Can you try reading the P12 again, and perhaps also using the slow speed mode (that will take a while to complete)?
If you need to send the file to support just email me at support@efilive.com. What will probably also be useful is the debug file (http://www.efilive.com/index.php?opt...111&Itemid=121). Please only send the single file that relates to the read attempt.
Andrew
EFILive Crew
Glad to see someone is back on the P12 stuff .
I have not tried lately will give one a try tomorrow and see what happens .
2006 Trailblazer
Still cannot flash the 03 Duramax, it says interface not detected, and then goes on to give mr the bootloader rejected message? I tried high speed and without, no luck, is it possible that this ECM is toast?
Suncoast SCIV 1056
Billet pick up
MBRP 4" exhaust
Air intake horn mod
ARP head studs
Tuned with EFI
Can you read it? Technically there's no difference between executing the read boot loader and the write boot loader, so if the read boot loader works OK, then there's nothing wrong with the ECM.
If you want me to investigate it further, send me the blx file for the failed attempt.
It worked!!!
Suncoast SCIV 1056
Billet pick up
MBRP 4" exhaust
Air intake horn mod
ARP head studs
Tuned with EFI
