Results 1 to 10 of 18
Thread: TCM dead after flash
    Default TCM dead after flash
    On a 2009 G8, I flashed the TCM and it failed when finished. I tried several times to flash it and it would always fail. The car was undrivable and in the middle of no where. I unhooked the batt for a few mins and was able to reflash it. Im scared to reflash it again, what happen?
    Were you able to get vehicle driving again...?
    Lorenz, are you using the latest release? We've had another complaint of this happening just recently.
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Subscribing....
    Jan 2004
    What did you change in the TCM file? Anything out of the ordinary?
    yes only after unhooking the batt and reflashing the TCM
    Yes, the latest. This is also the same G8 that says contact dealer when I plug into with it runing.
    Quote Originally Posted by Black02SS View Post
    No, just your normal basic trans tune without tq management. I was actually putting back my old tune I had in for the last couple thousand miles.
    Oct 2005
    Upgrade your firmware as well mate. I think that issue was resolved in newer firmware. Though maybe you have done that already..
    2014 VF SV LS3 Maloo.
    Quote Originally Posted by ringram View Post
    Have the latest..........usually I update within a day or two of something new coming out.
    Default So far.....
    So far, Ross seems to be the only person to have killed a T43 in the name of EFI LIve Tuning!
    I've done evil things to T43s even including accidentally yanking the usb from the laptop in the middle of a TIS flash!
    While I had a few scares, I've NEVER had one go south.
    Shutting the battery off or grounding the positive bat cable (WITH THE POSITIVE CABLE DISCONNECTED FROM THE BATTERY) to the negative is all I've ever had to do.
    Proceed as usual...It was likely a fluke and I wouldn't sweat it.
    Chuck CoW
  1. Full flash and batteries went dead. ecm not working
    By 05DirtyMax in forum Duramax LLY
    Last Post: February 1st, 2010, 01:00 PM
  2. Another TCM dead after re-flash
    By minytrker in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 4th, 2009, 11:52 AM
  3. Is my PCM dead?
    By kenkaru in forum Gen III V8 Specific
    Last Post: March 22nd, 2007, 07:08 AM
