Results 1 to 7 of 7
Thread: Strange...missing column???
    Jan 2007
    Default Strange...missing column???
    It's really late..well..early and I've been up all night....so maybe I'm missing something...but...
    When opening mine and various other tunes and looking under 'Transmission Calibration', 'Desired Shift Times'.....I see this under the description:
    Determine the desired 1-2 shift times for the transmission adapt values.
    There are 3 modes of transmission operation:
    1. Normal - This is the normal operating mode of the transmission.
    2. Performance - Some vehicles have the option to switch to a performance mode shift pattern.
    3. Cruise - If cruise control is active.
    Setting any value to 0.00 will disable adaptive shift learning.
    However....there are only two columns. Normal and Performance....no Cruise???
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Howard,
    I just went and looked in mine and I see the same thing... hmmm...
    I have a feeling it might be just a misprint in the description, but I notified Tech Support anyway.
    Joe
    Sometimes copy / paste descriptions don't work so well
    Jan 2007
    Lol! Thanks guys.
    Sorry Ross.
    Also Ross....what's 'Bi-Irectional Response Code'?
    Lol! That's what it says in my PID list????
    Howard
    DUCT TAPE.
    Aug 2008
    Quote Originally Posted by hquick View Post
    Lol! Thanks guys.
    Sorry Ross.
    Thats a good one....Hahaha...
    FLASHSCAN V2 & AUTOCAL
    Jan 2007
    But it's TRUE!
    Howard
    DUCT TAPE.
    Aug 2008
    Whoa! Bi-irectional......
  1. Column Lock Option
    By Ninety8C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 13th, 2009, 07:57 PM
  2. 01 Corvette, column lock, G0801
    By edcmat-l1 in forum Gen III V8 Specific
    Last Post: April 22nd, 2009, 03:23 PM
  3. Corvette steering column ?
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: June 6th, 2008, 02:51 PM
  4. Creating a one column table.
    By 2002_z28_six_speed in forum General
    Last Post: August 5th, 2007, 09:56 AM
