Results 1 to 3 of 3
Thread: 4low and tow/haul are reversed
    Mar 2009
    Default 4low and tow/haul are reversed
    I had read about this in a post before over at DP, but I made some changes to the shifts in 4X4 low range(table B) and found out that they change the shifts in tow/haul mode. And judging by the shift points it looks like the tow/haul shifts(table D) are actually 4X4 low. This was with an 02 OS in an ALLISON TCM for the DURAMAX. I switched back to the 01 and I will try and see if it is the same way or not.
    OS-15172881 calibration-15172884
    Mar 2009
    Well I checked my 01 OS and the 4X4 low and tow/haul are all reversed in it as well. I just have to remember that schedule B is for tow/haul and schedule D is for 4 low. Also as far as I can tell in all of the LB7/LLY TCM OS's I looked at the 2 are reversed if I compare the shift points in each OS.
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Yeah the tables are not accurate. I mentioned this to Ross and Paul at SEMA. Table A is correct, but that's it. Tables B and up are messed up.
  1. tow/haul mode?
    By THEFERMANATOR in forum Conversions / Aftermarket Parts
    Last Post: February 3rd, 2010, 07:43 PM
  2. Tow/haul mode
    By rennoc442 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 21st, 2009, 08:31 AM
  3. tow/haul transition
    By Ritch in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 4th, 2008, 04:01 PM
  4. Tow / Haul
    By mcwarren in forum Custom Operating Systems
    Last Post: February 28th, 2006, 06:39 PM
  5. Tow/Haul Mode
    By 87gmc in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 19th, 2005, 11:54 AM
