Was wondering if one of you kind folks could guide me through how I can do this. Should be simple enough. Read this in a "Corvette Fever" article off the main site:
"When you open a stored data log and move the cursor to a position within the recorded chart, the "coordinates" of that point are highlighted on the relevant calibration data table and/or graph within the tuning program. As an example, if you move the cursor along a recorded data graph to a position where spark knock is indicated and then click over to the spark map in the tuning program, the cell that corresponds to the engine rpm and engine load, when the knock occurred, will be highlighted. The contents of that cell can then be changed to a lower value that will not precipitate spark knock.
Similarly, if you move the cursor to a position where excessive fuel trim is indicated, or where the wide-band O2 sensor indicates the actual and commanded AFR are off a good amount, the appropriate cell in the VE map is highlighted. It's also possible to "click and drag" across a data chart to highlight a range of data points. When you switch from the scanning to the tuning program, all the cells that relate to the data points on the graph are highlighted. This capability eliminates guess work as to which calibration values relate to actual operating conditions and greatly simplifies tuning."
THANKS! (I know the article pretty much describes what to do, just want to confirm that I need to have both programs open separately or there is a way to access TUNE from SCAN.)
