I've just purchased my EFI software and I want to purchase a wideband O2 sensor to go with it. Any suggestions would be appreciated.
Thanks,
Phil
Thanks,
Phil
I currently am using a LM1 and really like it. Several are using LM1's, LC1's, FJO's, and the PLX's. If you stick to one of the above I don't feel you could go wrong. My preference is the LM1 or FJO.
I use an LM-1 and am very happy with it. I chose this one because I use it in my car and in friend's cars. If I were just using it im my car I would most likely use the LC-1.
02 C5 Coupe - LS7, TSP 265 LS7 heads, ARH, Z06 cat-back, HREs, 3.73 gears, Wilwood brakes, DeWitts radiator
15 C7 Z5 1 Coupe - stock for now
12 Avalanche - tune, Corsa Touring
