Thread: Speedo tuning...difference between H0103 and H0122?
    Senior Member thunder550's Avatar
    Default Speedo tuning...difference between H0103 and H0122?
    06 LBZ. RPO code for the truck says 3.73 gears. Trans tune says H0103 is 4.10, H0122 is 3.73. Which one is the gear ratio? What's the difference between the two? Shouldn't they be the same?
    I'm confused!
    I think I remember hearing that all the TCMs say 4.10s even if the truck has 3.73s or whatever other gears.
    Mar 2009
    All the TCM's are set to 4.10 gears. This has nothing to do with the speedo in the truck, but how the TCM sees the speed reading. The general consensus is leave the TCM settings alone for the speedo as it uses the 4.10 ratio for figuring shift times and torque numbers. By changing it you will essentially change all of your shift times and cause tie-ups which will destroy your ALLISON.
    Jan 2008
    Quote Originally Posted by THEFERMANATOR View Post
    Yes X2. Just leave the speedo stuff alone in the TCM. All that stuff in the TCM speedo is for internal calculation and has nothing to do with the speedo reading on the dash.
    Ok so if my speedo is off I need to change it in the ECM then instead of the TCM?
    Jan 2008
    yes that is correct
  1. Speedo calibration VSS in Scan not same as speedo
    By maudyZ28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 23rd, 2010, 01:47 PM
  2. 09 LS3 TB difference
    By ForcedC5 in forum Gen IV V8 Specific
    Last Post: April 20th, 2010, 12:32 AM
  3. What is the difference between shifting VSS and RPM?
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2008, 06:34 PM
  4. Difference between BEN and AFR MAF calibration?
    Last Post: January 7th, 2008, 07:47 AM
