Custom Tuning Services
Yeah SoCal pretty much had the corner of the market for DSP switches, and he made his backwards form a logic standpoint. So thats how i make mine.. Base is last all the way to the right and stock is all the way to the left... Like turning up the volume...
and now since i suggested that he has released a new design... opposite of what he way producing before...
It started with a thread in the Beta forum about 2 months ago...
I told him I thought of it first, 3 months ago, LOL.
I am not criticizing anyone though. If I weren't doing the keylock project, something I wanted to do about a year ago, I would have just left it alone.
Keep in mind what I had said about the logic flow of the DSP switch position check, if you start producing switches that don't work the same way the ECM determines the DSP position you probably won't be able to select all the tunes. I had also mentioned that the ECM will use the factory table locations (non DSP) when the voltage is at it's highest, given that, this should be the tune you want should the switch ever go faulty (open circuit).
Right. I have considered that and it is much easier to do it this way, rather than taking all the limiting tables from a big tune and pasting them to a stock tune just so the big tune doesn't get limited by the stocker some how. And besides that i run the big tune on a daily basis and am completely fine it the switch faulted some how....
