Results 1 to 6 of 6
Thread: Bluetooth problems
    Jan 2006
    Default Bluetooth problems
    Well after having my RR stored for the last year I dug it out today and set it up on my new laptop. It works fine with the USB cable but when I tried blue tooth it wont connect. I see, enter the password and pair to it but when I click the green button it says cant find usb cable or something like that. I dont understand why it isnt working if its paired to my laptop? Im using vista 64bit if that matters.
    Nov 2006
    I have found certain BT stacks work better than others.
    Are you using the MS stack or another?
    Check the BT stack's port settings and the tune tool software.
    Guidance for getting things up and running with BlueTooth on Moates.Net products
    LC-1 WBO2
    Nov 2006
    Did you get this working?
    LC-1 WBO2
    Jan 2006
    No, I tried that first. It connects to it fine, It just wont communicate with it.
    Nov 2006
    So, it won't up/download or is the problem with RTACS?
    LC-1 WBO2
    Jan 2006
    Quote Originally Posted by mr.prick View Post
    won't up/download
  1. Bluetooth Help Please
    By NERDPWR in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 6th, 2008, 09:10 PM
  2. thinking of getting bluetooth dongle...
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: May 22nd, 2008, 09:18 AM
  3. Bluetooth and RR
    By 5.3 in forum RoadRunner Real-Time PCM Emulator
    Last Post: February 4th, 2007, 10:06 PM
  4. Bluetooth RR at last
    By limited cv8r in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 12th, 2007, 08:07 AM
