hey guys, so I'm preparing my truck for going boosted, would anyone mind looking over my tune and see if I missed something, especially the spark tables.
some specs:
1996 C1500 L31 5.7L, T56 M6, 24x crank sensor conversion, LS2 coils, RHS heads, ZZ4 cam, custom MPFI intake running balanced ford "giant blue" bosch EV6 39# injectors at 43.5 psi (flow tested at 417.4cc/min), TR6 plugs gapped at .040, 180* Tstat, Whipple with stock 6ish psi pulley, air to water intercooler, 75mm TB, regular bolt on stuff (headers, efan, etc), full OLMAF, 2bar MAP...
Thanks guys, I'm somewhat new to the boosted scene and am looking forward joining the boosed crew, heh.
just FYI, the tune is based off a 2002 LS1 camaro tune with some tables taken from a 2005 Z06 LS2 tune, and some of my altered ones from prior to the heads/injectors/24x setup. I'm planning on getting my fueling in line from the heads/injectors prior to installing the whipple.
