Results 1 to 10 of 10
Thread: Engine Trans Dyno Tuning Questions!
    May 2009
    Question Engine Trans Dyno Tuning Questions!
    Hey guys,
    Several questions.
    First the plan, I'm looking into setting up a Gen IV (or Gen III converted motor) on a test stand with an electronic transmission (a 6L50/80/90 variety) to test some things.
    Now I know the new CAN system plugs a lot of things in, so I'm curious about a few things regarding the ECM.
    First, can the E67 can be 'programmed/tuned' to run the engine and/or tranny stand only (i.e. out of the vehicle) to ignore all 'vehicle' modules?
    Off hand I'm thinking the only thing I'll need to add to this test stand (besides obviously the engine sensors) will be an interchangeable 'pedal sensor' for throttle application. I'm thinking the VSS on the tranny should be enough input for the tranny to go through its cycles without issues.
    Second, am I correct in thinking that to take a Gen III engine to a Gen IV (as far as the ECM is concerned) requires swapping out the 24X crank reluctor ring to a 58x and changing the 2x Cam Sprocket to a 4x?
    Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
    You can run the E67 standalone easily, turn VATS off and apply the patch.
    May 2009
    Cool...thanks man!
    May 2009
    What's the minimum EFILive package that I need to do this? Or can I just have a local tuner flash the ECM?
    Jan 2005
    How are you going to control the trans? E67 has engine control capabilities only. If you're going to use an electronic trans, you'll need a trans controller. Depending on the trans, some controllers are built in, others are separate.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Senior Member MyM8V8's Avatar
    Aug 2008
    Some Gen IV's have a 24x reluctor.
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    May 2009
    Exclamation
    Quote Originally Posted by dfe1 View Post
    Just plan to let the trans run on its on...don't plan to mod or tune it.
    Quote Originally Posted by TBMSport View Post
    EFILive Scan and Tune V2. You can have a local tuner flash it but believe me you'll be better off buying it and playing with it yourself. Plus then you dont have to pay a tuner to come over every time you need to make a small change in the tune. It could be as easy as doing one flash to kill the VATS but in all reality you'll be playing with the tune a bunch to make it work.
    He's looking to use the 6L80/90E so the T43 is built in.
    Quote Originally Posted by MyM8V8 View Post
    Yep, this setup will be only be for 58x guys for now until someone makes a 24->58x box (like the Lingenfelter 58->24x but reversed).
    You're going to probably end up tuning it, but yes initially leave it just as GM produced it to make sure everything is compatible.
    May 2009
    Exclamation
    Working on an adapter kit for that.
    Aug 2008
    I thought that box worked both ways?
  1. LBZ on an Engine Dyno
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 25th, 2008, 04:32 AM
  2. LS2 472bhp out of the crate (engine dyno)
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: June 3rd, 2008, 02:22 PM
  3. Trans/TCC tuning questions -- AFR side effects?
    By turboberserker in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 28th, 2006, 03:49 AM
  4. Trans/TCC tuning questions -- AFR side effects?
    By turboberserker in forum General (Petrol, Gas, Ethanol)
  5. Street vs Dyno AFR variances? Also, PE/fuel trim questions..
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 20th, 2005, 12:45 AM
