Ive been trying to AutoVE and have found that my V2 doesn't record correctly what my widebands analog is outputting.
I have a FAST wideband, and noticed the the V2 was reading differently(on my laptop) than the FAST display. The FAST PIDs use the high resolution which has a calculation I cant do in my head, so I made it easy on myself by switching to low rez so I could diagnose what was happening a little better.
The FAST low rez has an output that is (V*10). So I searched through the other widebands pre programmed and found the LM1 uses the same calculation, so I setup to record V*10 on the FAST and in the LM1 in the EFILive Scanning.
I run my truck, and turn it off(key back on), so it holds A/F steady. I then check the FAST display and it reads 13.8 and is solid. I check my laptop scanning and its bouncing from 12.0-14.6.
So I take my multimeter to my analog output(orange piece that plugs into the V2) and check the actual voltage being output and its 1.38x and very steady. This tells me the FAST wideband is telling the V2 exactly what it should, but the V2 is just not reading it correctly to allow me to AUTOVE correctly.
Any ideas? Ive rechecked that the connection was tight, and that the connector is plugged into the V2 all the way.
