Results 1 to 5 of 5
Thread: rear o2 function?
    Lifetime Member smslyguy's Avatar
    Oct 2008
    Default rear o2 function?
    I am woundering what the true function of the rear o2 sensor actually are. I do understand that they are montoring the cats, but can they actually add or subtract fuel?
    2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
    Now own a 2015 1LE camaro
    Junior Member LM7Tuner's Avatar
    Sep 2009
    The purpose of the rear oxygen sensor is to monitor the oxygen content of the exhaust gases leaving the catalytic converter. This gives the emission system a way to monitor the operation and efficiency of the catalytic converters. The rear oxygen sensor checks several things in the post–catalytic converter gases. It measures the amount of oxygen, or peak threshold, in the exhaust gases and follows how fast the amount of oxygen changes. On some vehicles, the rear oxygen sensor is mounted midway in the catalytic converter to measure how efficiently the reduction bed converts NOx by checking the amount of oxygen that is released back into the exhaust flow.
    Jul 2004
    More simply, the rear O2 sensor is not to my knowledge used for adjusting AFR, it is only used to confirm the operation of the CATs.
    Ira
    Oct 2008
    Quote Originally Posted by Ira View Post
    Ira
    so if you the rear o2 sensor's are reading that the cat's are malfunctioning is there anything the 02 sensor's do besides through as mil light?
    Quote Originally Posted by GM Service Manual
    Catalyst Monitor Heated Oxygen Sensors
    In addition to catalyst monitoring, the post heated oxygen sensor has a limited role in controlling fuel delivery. If the post HO2S signal indicates a high or low oxygen content for an extended period of time while in a closed loop, the PCM adjusts the fuel delivery slightly in order to compensate.
    Do note that this is an abnormal condition.
  1. t43 rev-matching function
    By pontnewynyddboy in forum Gen IV V8 Specific
    Last Post: October 7th, 2009, 11:06 AM
  2. New Function in Build 80
    By ChipsByAl in forum General
    Last Post: February 13th, 2009, 07:06 PM
  3. rear axle max torque and rear prop shaft numbers
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2006, 04:10 PM
  4. What do you think? (ctrl) Function
    By Black02SS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2005, 11:13 AM
  5. Integrate function(s)
    By joecar in forum General
    Last Post: July 16th, 2005, 08:48 AM
