Results 1 to 5 of 5
Thread: sled pulling tune
    Junior Member browneflatwork's Avatar
    Nov 2009
    Default sled pulling tune
    What do I need to do for a sled pulling tune. I have heard to increase shift points in 4lo. I'm confused with the different tables (A-D), I was looking at shift points and there is MPH and RPM, which one do I want to change? And since there are separate ones for T/H and 4Lo, which one do I want to change. I always pulled before I had EFi in 4lo with T/H on. If i change the 4Lo shift points will I still want to pull in T/H or would that override my changes? Another question I have is about the description of the tables (A-D), they say the shift points I am changing are for when I am in "D", is there something else I should be looking at or is that just a general description? Are there things I should do with TC lockup also?..............new too EFI thx
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Well you can eliminate some of your confusion,
    Just decide what you want the tranny to perform like in 4low and tune it to your satisfaction without the worry of tow haul and the additonal tuning. Tow/haul affects TC lockup, if you like the feel of the lockup and the extra power to the ground, you can simply copy the TC lockup points over to your 4low TC lockup points for each gear, so you won't have to activate your tow haul button. And you'll want to tune shift points in "D" mode unless you're using "M" for manual mode. The different operating ranges consist of normal, hot tranny, tow haul, manual, etc. Your tranny should be operating in "normal" mode unless it overheats or limps (I'd leave those adjustments alone for protection), or if you're in manual mode or tow haul. Make sense? Let me know if I've confused you, I was new too my friend
    Peace Through Torque
    www.PunisherPerformance.com
    Nov 2009
    ya that helped.......i normally put my truck in 3rd gear so i should tune in "M"???? sry i am extremly new to EFI its still in the MAIL!!!!!! lol shouls be here any day though....just asking lots of ????? and tryin to soak up as much as i can!!!!!!! thx for the help!!!
    Jun 2008
    Yeah you'll want to tune the "M" range, up to 3rd gear or just 3rd gear, however you want to do it man. If you have any more questions I'll be glad to try and help out. Send me a private message and i'll give you my email too if you want.
    Nov 2009
    will do thx
    EFI....SC IV,fass 150,sleeves, MBRP 4in TB,afe intake, shimmed rail, blocked egr,auto meter c2 gauges, home built trac bars,
  1. pulling tune "allison"
    By drdiesel in forum Allison 5 & 6 Speed
    Last Post: May 24th, 2009, 03:13 AM
  2. sled pulling tune
    By remington_43040 in forum Allison 5 & 6 Speed
    Last Post: April 15th, 2009, 02:20 PM
  3. Pulling out tune with Pin56 COS
    By Hawgjawz in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2008, 12:10 AM
  4. Pulling vaccum at WOT
    By cmitchell17 in forum Gen III V8 Specific
    Last Post: September 30th, 2007, 01:55 PM
  5. Pulling timing
    Last Post: August 27th, 2006, 05:40 AM
