Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Connection drops
    Nov 2006
    Default Connection drops
    Since the last update my precious V2 looses connection to
    the PCM while logging for unknown reasons.
    This is unpredictable and quite annoying.
    Am I the only one going through this?
Name:	Dropped connection.jpg
    LC-1 WBO2
    No, there have been some other reports of this also. We still don't know what is causing it.
    If you are able to reproduce it consistently, please document the conditions so we can try and reproduce it here.
    Nov 2006
    I thought I could reproduce it, but I can't.
    I happens sometimes and sometimes it does not.
    All I know is that it start immediately after the new FW.
    If I power off the V2 then reconnect it will be fine.
    LC-1 WBO2
    Nov 2006
    Any news on this?
    Can I go back to the previous FW without consequences?
    LC-1 WBO2
    Nov 2005
    I can't log balance rates anymore.. Not sure if it was after the EDC16 DSP updates or not.
    Senior Member MyM8V8's Avatar
    Aug 2008
    I've had this happen before on my earlier version,but I put it down to the small lap top going to sleep. It was a very long log though about an hour an a half.
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    Oct 2009
    I have been trying to get a scan on a 97 lumina 3.1 I had given to me.
    but it will not allow me to see the standard pids. for example when i try to access the vss it is listed as not currently valid.
    Also when I try to get DTCs it stalls the car. this battery is so bad it will not start the car again without a boost.
    I'm posting to this thread as I'm pretty sure the cause is the bad battery which I need to replace. may or maynot be the cause of some disconnects some have had.
    Any thoughts
    Alex
    Alex,
    Did you validate pids after connecting to the 97 Lumina...?
    Oct 2009
    Alex,
    No i did not but will after I get the new battery.
    Thanx
    Nov 2006
    Bump for a FW fix.
    LC-1 WBO2
  1. Not connection to E67 ECM
    By khalidmmukhtar in forum E37, E38 & E67 PFI ECM's
    Last Post: March 9th, 2010, 08:40 AM
  2. what table controls how fast it drops to idle when slowing down?
    By mvvette97 in forum Gen III V8 Specific
    Last Post: September 8th, 2009, 09:18 PM
  3. No connection!
    By jamesbond2509 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2008, 12:33 PM
  4. No connection
    By jannes_z-28 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2007, 08:57 AM
  5. OL drops into CL temporarily...
    By dc_justin in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2006, 08:17 PM
