Conditions for Running the DTC
The DTCs run continuously once the following conditions are met:
DTCs P0171, P0172, P0174, and P0175
No Throttle, Fuel Injector, Air Flow, Purge Control, MAP, or other Heated O2 Sensor faults active.
The engine coolant temperature is -40 - 139°C.
The MAF signal is between 1 - 250 g/s.
The MAP signal is between 15 - 105 kPa.
The IAT signal is between 0 - 152°C.
The engine speed is between 400 - 6500 RPM.
The vehicle speed is less than 130 km/h.
The fuel tank level is more than 10%.
Conditions for Setting the DTC
DTCs P0171 and P0174
The following conditions exist:
The average Long Term fuel trim value is greater than +24%.
