Results 1 to 5 of 5
Thread: Automatic Driver Loading
    EFILive Distributor Trippin's Avatar
    May 2004
    Default Automatic Driver Loading
    I still get tech support calls from people that have trouble with the EFILive driver not automatically loading. Seems most of the calls are from people who have downloaded the software from the web site rather than installed from the EFILive disk.
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    The users that have trouble, are they running Vista? Or XP as well?
    Vista is a PITA for drivers.
    Oct 2006
    I am going through all these driver issues again after the last update on XP. I still havent got my roadrunner going as yet.
    FWIW I was having trouble with the automatic installation & had to download from the site & manually reinstall.
    The Tremor at AIR
    Oct 2004
    The RoadRunner can be a little tricky as it identifies itself as a generic FTDI part, and therefore the latest drivers are pulled from Windows Update. I have found previously that if you want it to operate as a Native USB device (and not a Virtual COM Port) you have to update the driver from the 'C:\Program Files\EFILive\Drivers\EFILive\Win-2K-XP-Vista' driver location (same driver used by FlashScan).
    Andrew
    EFILive Crew
    Oct 2006
    Cheers Andrew.
    I will be having another go at this tonight .
    The Tremor at AIR
  1. Wiping Automatic Codes???
    By strongarmz in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2008, 01:13 AM
  2. automatic updates
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2008, 03:28 PM
  3. 4th to 2nd Downshift (Automatic)
    By TNTFEDZ in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 18th, 2006, 01:19 AM
  4. SD tune + Automatic
    By Phil99vette in forum General (Petrol, Gas, Ethanol)
    Last Post: August 10th, 2005, 04:35 AM
  5. What MPH shifts for 342 gears with an automatic?
    By 02pewterls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 15th, 2005, 03:08 AM
