Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: Will a 6 pinion planet gear work in 4L65E
    Senior Member MyM8V8's Avatar
    Aug 2008
    Default Will a 6 pinion planet gear work in 4L65E
    Hi,
    We are building a new box for next year and are considering installing a new 6 pinion planet gear in place of the stock 5 gear one to even out the ratios.
    Is it possible to reprogramme the gear ratios to suit this set up without any issues?
    Thanks in anticipation. Gareth.
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    Gareth,
    Do you mean the 6-pinion gearset from PATC (find "6 pinion" on this page): www.transmissioncenter.net/4l60e.htm
    My understanding is that the gearset fits the 4L65E (4L65E is interchangeable with 4L60E)... but, to be sure contact PATC and ask them directly.
    The PCM transmission calibration has editable gear ratios, see D1201-2 and D4601... set these to 1st=2.84 and 2nd=1.56.
    I do like the closer ratios, you don't need as loose a stall converter as you do with the stock ratios.
    Lifetime Member N0DIH's Avatar
    Jan 2006
    $1100+....owch....
    I owned a Ford once, ONCE.......
    Aug 2008
    Gareth,
    Yes, Joe, that's the one. I suppose the stall is also affected by where the cam is as well, but there is a definite advantage to having a tighter stall when you have a dual purpose truck, i.e. street/strip.
    What I was really getting at was; with the gearbox ratio calibration applet, I recall vaguely there were some issues with the software and calculations and I did have problems using it to (unsuccessfuly) recalibrate my speedo from kmh to mph.
    It would be handy to know if there are any guys who have used it to change the ratios successfully in similar circumstances. What worried me was on the PATC site it referred to certian setups throwing ratio codes. So I thought I'd just check here first.
    As NOD1H has said, it's a lot of money if it don't work, but if it does, it could be the best upgrade in the box (Well apart from a 300m input drum).
    You mean the Speedo Calculator... the speedo comes from the VSS signal which is taken from the reluctor on the trans output shaft... changing the trans internal gear ratios doesn't change VSS relationship to the output shaft...
    I would just manually calculate and edit all the tables that are affected by a VSS relationship change.
    Someone here (slow67) is running a 4L80E on a 4L60E calibration (to keep the TCC locked at zero throttle)... it seems he did not edit in the 4L80E gear ratios (2.48, 1.48, 1.00, 0.75) so he got some codes: showthread.php?t=11975
    It will throw codes if the calibration is not edited with the new ratios... the PCM computes in each gear what the RPM:VSS ratio should be based on the current gear ratio and whether the TCC is locked... if it does not agree then a code is set.
    You may have to edit the 1->2, 2->1, 2->3, 3->2 shift tables (PT and WOT) since 1st and 2nd gear are now numerically lower (the max (engine redline) MPH in 1st and 2nd is now higher).
    It's a lot of money, but you get various benefits: it's stronger than the 4 or 5 pinion sets, it gives closer gear ratio spacing, allows you to use a tighter stall converter, and others.
    Aug 2008
    Default Off topic help needed Joe.
    Hi Joe,
    Wondered if you could help. I am trying to sort out a heavy duty input drum assembly from PATC and I'm not quite sure which one I need?
    There are two available, one for 2007 up and one for before. The difference is the reluctor for the speed sensor on the shaft.
    I have a 2005 in the ute and the one coming from Holmart is a 2006YOM.
    They are asking which color case connector I have and I dont; know.
    Cheers if you can help.
    Interesting, that 6 pinion gearset looks really promising. Im going to ask the guys in the TBSS world if it might be a better way to lower E.T.s. Wish it had a higher (numerically lower) OD gear than .70, Id love a .65 or .60 OD gear with these 4.10 gears. Kills the mileage on the hwy when you're spinning about 2600rpms going 75mph. My regular TB with 3.73s spins about 2300 at 75...
    Aug 2008
    Interesting, that 6 pinion gearset looks really promising. Im going to ask the guys in the TBSS world if it might be a better way to lower E.T.s. ...
    They're claiming up to 3/10ths.
    Quote Originally Posted by MyM8V8 View Post
    Hi Joe,
    The input drum/shaft with the reluctor teeth is for the 4L65E/4L70E variants that have the ISS (input speed sensor)...
    the stator support shaft has to allow space for the reluctor teeth;
    If you don't have the ISS then you want the other input drum...
    The electrical connector on the case...?
    If you look at it you should be able to see what color it is...
    (on RHS of case, on flat "wing" above the pan (rearward of where dipstick tube fits)...
    it is most likely Grey... but I don't have any diagrams later than 2005.
    Aug 2008
    You are right. It is grey. I just need to find out whether I have ISS.
    Once again. Thanks Joe.
  1. 4L65E (with LS2) in RX7
    By MyM8V8 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 12th, 2010, 04:35 AM
  2. What gear am I in??
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: September 9th, 2009, 04:06 AM
  3. scanner buttons work work?
    By pullincrazy88 in forum FlashScan V2
    Last Post: May 16th, 2009, 01:12 PM
  4. Stock 4L65E sluggish 1-2 shift at light throttle - Dashboard attached
    By pacer265 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 12th, 2008, 06:25 PM
  5. Modulated 4l65E
    By Forum 12 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 30th, 2007, 12:05 PM
