I'm wondering... you might be able to use the reluctor input drum/shaft if you use the stator support that goes with it... check with PATC if the ISS style stator support works in a non-ISS transmission... if it does, then you would be able use that input drum/shaft.
Ask them if both parts fit into a non-ISS 4L60E/4L65E.
